We’re starting to look at implementing GSLB for various of our external services.
All of the documentation says we should add our BIG-IP devices in our other data centers via DNS > GSLB > Servers and add using its external IP address.
We do not connect our F5’s directly to the internet, instead the NAT is handled by our Firewalls. What IP should I use or how should i configure the server?
With just their internal management IPs? (Both datacenters are linked via Layer 2 direct fibre so we can contact without having to go out externally)
With the IPs they have in our pool subnet?
Or do i add and put the external address that the GTM DNS listener will be on and have a translation to the internal GTM DNS listener address?
Any pointers are appreciated.
Hey @Arron_F
In your case, add BIG-IP LTMs into the DNS using their internal Self-IPs, assuming they are reachable through the MPLS/dark fibre
internally. IQuery would happen through this private link. However, when you define virtual servers within the server objects, the following procedure is recommended.
You can add either a virtual server or a pool-level monitor to achieve more precise control.
Creating BIG-IP LTM virtual server objects for BIG-IP servers that reside behind a firewall, NAT
The IP address that you define as the virtual server address for a BIG-IP LTM virtual server is the internet-facing firewall NAT address that clients use to access the virtual server services. The translation address of a virtual server is the private network address defined for the virtual server on the BIG-IP LTM system.
For example, consider a case in which the BIG-IP LTM system’s virtual server private network address is 10.0.0.111, and the firewall Internet-facing NAT address is 65.61.115.223.
When you add the BIG-IP LTM system’s virtual server to the BIG-IP DNS system, you enter the IP addresses in the General Properties section, as follows:
Address 65.61.115.223
Translation 10.0.0.111
