Hello, I would like to monitor the number of user connected on our platform with their VPN Edge Client.
What is the OID number to be able to monitored the number of users connected with VPN via our monitoring tool ?
BR
BR
there is unfortunately not one available by default, you have to create a script and hook it up to SNMP
look here for how to: myF5
thank’s. But when I test to request the OID, I have an error : SNMP_EXCEPTION_NOSUCHOBJECT222
BR
did you create the scripts?, restart SNMP daemon on F5?
Yes I did…
weird, what if you try locally, might have to change community string
snmpwalk -Os -c public -v 2c localhost .1.3.6.1.4.1.3375.2.100.1
With localhost or the IP address of the Mgt, I have the same answer : Timeout: No Response from localhost. But the process is running…
no it’s working but I have this error now :
bigipTrafficMgmt.100.1 = No Such Object available on this agent at this OID
not the answer you want, but something went wrong in the steps then
can you run
/config/snmp/ccuUsage.sh
do you get the current number then?
any errors in /var/log/ltm when you restarted the SNMP daemon?
Yes I have 622.
And no error in ltm
I found this OID :
apmGlobalConnectivityStatCurConns ou 1.3.6.1.4.1.3375.2.6.1.5.3.0
By requesting this OID, I have the number of CCU licenses consumed. With this value, I see the CCU licenses consumed therefore the number of VPN connection on the plateform. Right or not ?
unfortunately not, if you compare that value against the output of
tmsh show apm license
it is different.
i tried a totally bad
/config/snmp/custom_mib.tcl
but that doesnt get me any errors.
can you share the content of your custom_mib.tcl
bigipTrafficMgmt.100.1.0 = Gauge32: 37
But I would like to understand. If I see the dashboard, I see the same number about Active Access Session than the command and I have also 5 open about Network Access Connection (as you can see in the screenshot). What is the différence ? The number about Network Access Connection is not only the number of VPN connected on the system via the EdgeClient ? And the 37 active access session is only the number of session open on the system to reach our Sharepoint Web portal (without tunnel access) ?
I’m sorry if my question is stupid…
BR
great the SNMP works.
the result is interesting, can you also show the tmsh output to be sure. in principle that SNMP shows the connectivity license usage which is network access but also some other things.
see what counts as CCU and not: myF5
Hello
Find a new screenshots where we see 36 active access sessions and 4 Network Access Connections. I attached also the result of several commands :
1/ snmpwalk -Os -c public -v 2c localhost .1.3.6.1.4.1.3375.2.100.1 where the result is 36 as the number of active access session we seen in the screenshot dashboard
2/ The result of tmsh show apm license where we see the information about licenses
3/ config # snmpwalk -Os -c public -v 2c localhost 1.3.6.1.4.1.3375.2.6.1.5.3.0 where normally whit this OID, we see the number of CCU licenses consumed and the number (4) is the same number than the number of Network Access Connections in the dashboard screenshot..
I added also a screenshot to see active sessions in the F5. We see 36 connections but for me this number include the portal access (without tunnel resource) AND the number of VPN connections. So for me, the result of the first command is the number of total connections on the system, not only the number of VPN connections.
For me, the CCU is the licenses used when in your policy, you define a tunnel resource and access session is only for access without tunnel or rewriting policy
thanks, i might not understand what you are now exactly asking.
to repeat my understanding: CCU is not equal to VPN access
1.3.6.1.4.1.3375.2.6.1.5.3.0 seems to show network access connection, which is nice information but that is not the only thing that counts towards CCU
1.3.6.1.4.1.3375.2.100.1 truly shows CCU and is important for your license limit
sorry, I’m not clear…
My management request to me to have the information about the number of VPN connections on our system
that is four in above info
OID 1.3.6.1.4.1.3375.2.6.1.5.3.0 seems to show you that
but do keep in mind that the number itself is useful to know, but it isn’t a license limit on itself
Hello Jerome, I believe that is correct. If you look here you can see what OIDs are available. You also have ones such as apmAccessStatCurrentActiveSessions and apmAccessStatTotalSessions:
Hello
When I execute locally on the BIG-IP the command “snmpwalk -Os -c public -v 2c localhost .1.3.6.1.4.1.3375.2.100.1”, it’s working. But when I tried to launch this command from remote server with snmpwalk -Os -c public -v 2c IP_of_BIGIP .1.3.6.1.4.1.3375.2.100.1, the command failed. And if I try the same command but with another OID (1.3.6.1.4.1.3375.2.6.1.5.3.0 for example), it’s working.. Do you know why ?
