Any advantage to setting up SNATs versus just using the auto-map function in the virtual server?
Thanks,
-Ken
Thanks,
-Ken
A little more control… (e.g. seggregation of traffic by srcip).
More connections… (Important for lots of short lived connections where you may run out due to the 2xMSL TIME_WAIT status, or just for really busy LTM’s)
H
Makes logging easier as well. If you have a different SNAT Pool per VS, you’ll know where requests came from.
With 10.x tcpdump, you can also see the virtual server name in the packets. This line shows a SNAT to pool member SYN which was via the http_10.1.0.15_vs virtual server:
14:05:19.472966 IP 10.1.0.11.50954 > 10.1.0.100.http: S 3232923316:3232923316(0) win 4380 out slot1/tmm0 lis=http_10.1.0.15_v
A VS specific SNAT pool is still useful, but figured I’d throw this out there too.
Aaron
Posted By hoolio on 02/11/2011 02:11 PM
Aaron
Was referring more to firewalls, Netflow, etc…boxes that only care about IP/Port. Still, very cool reminder. I noticed that once and didn’t think anything of it. Didn’t even consider the application at the time.
To me, the biggies are (in favor of specific SNAT vs. Automap):
1) You can be much more flexible regarding ephemeral port exhaustion.
2) It helps reduce confusion when you’re troubleshooting.
3) You can tune the timeout values on a snat pool, unlike automap.
Also, CMP can complicate the ephemeral port exhaustion issues, and some folks out there consider it to be best practice to setup a 1:1 mapping between the Virtual Server and a dedicated SNAT pool.
-Matt
This is an old question, but I didn’t see one point mentioned.
If you use Automap, then it will use a Self-IP address. This address will be visible to clients, and will be pingable. Maybe you’d rather make your Self-IP addresses less exposed by having the virtual server use addresses from a special SNAT pool.
