Hi Everyone,
I need your help as I am trying to get the VSs that are associated with a specific SNAT pool from the command line.
Thanks!
Hi Everyone,
Thanks!
Think you may benefit from the following tmsh script: https://community.f5.com/t5/codeshare/config-search/ta-p/277819.
Hope this helps!
tmsh list ltm virtual one-line | grep "pool SNAT_POOL_NAME"
Remark: SNAT_POOL_NAME should not have the same name as an existing LTM pool (and this is a best practice btw)
Hi Amine,
Actually I was using this command, the problem is that it is giving me the whole configuration, while I just need the virtual server name.
So, is there any way to get only the virtual server name ?
Thanks!
Hi @Khaled_HA , you can use awk to print only the virtual name, so to expand on what was provided earlier:
tmsh list ltm virtual one-line | grep "pool SNAT_POOL_NAME" | awk '{print $3}'
Love this script, @whisperer …should be a default install when deploying new BIG-IP boxes…
@Khaled_HA - If your post was solved it would be helpful to the community to select *Accept As Solution*.
Thanks for being part of our community.
Thank you guys for the support!!
how to get a list of all the SNAT pools or snat-translation or automap details assosiated to all the vips in a partiton other than /Common, i am not finding any such comand or grep command.
I tried following but none of them are working or no output
list ltm virtual all-properties | grep -i -e source-address-translation
show ltm virtual all-properties detail | grep -i -e ‘LTM\|Destination’
list ltm virtual all-properties | grep -i -e ‘LTM\|source-address-translation’
list ltm virtual all-properties one-line | grep -E “LTM\|pool|Destination|source-address-translation”
list ltm virtual one-line | grep -E “LTM\|pool|Destination|SNAT_POOl_NAME”
list ltm virtual one-line | grep “pool SNAT_POOL_NAME” | awk ‘{print $3}’
I
Other than common? Use TMSH GUI and cd into partition. By default, you will only get list from /Common. So… tmsh; cd /partition_name; your list commands.
I hope my query is not clear
Here it is again
how to get a list of all the SNAT pools or snat-translation or automap details assosiated to all the vips in a partition, any particular grep command we can use , if anyone has done it before using grep command
Hi @F5_Design_Engineer , you’d need to build an iteritive script to accomplish that, first by listing all the vips in that partition, then listing out any snat or snat pool details by querying those objects directly. Can be done on-box with a tmsh script or off-box using iControl REST.
Here is another way of getting information for specific Snat Pool looking through multiple partitions.
To get a list of all your snat pools → tmsh list /ltm snatpool
To get a detail list of all vips using a specific snat pool
tmsh -c “cd /;list ltm virtual one-line recursive” | grep “Snat_Pool_Name”
To get a smaller list with hostname and VIP use the below command.
tmsh -c “cd /;list ltm virtual one-line recursive” | grep “Snat_Pool_Name” |grep -oe “destination \S\+” | cut -d: -f1
You will end up with destination hostname/vip address that contains Snat Pool called Snat_Pool_Name.
hope this helps someone.
