Hello,you have to know well this class , and i have i problem.
in NodeAdressmain.cs i can’t use those two methods:
-get_object_status
-get_statistics
When i try to use it, i have the exeption :
exeption caught in LocalLB:
iControl:LocalLB/NodeAddress::get_statistics()
Eception : Common : OperationFailed
primary_error_code : 17238054
secondary_error_code : 0
error_string : 01070826:3: current Update Partition Error …
I have the same thing for get_object status.
I just want to display the Node statistics.
methods in localLBAddress.cs(samples SDK):
[System.Web.Services.Protocols.SoapRpcMethodAttribute(“urn:iControl:LocalLB/NodeAddress”,
RequestNamespace=“urn:iControl:LocalLB/NodeAddress”, ResponseNamespace=“urn:iControl:LocalLB/NodeAddress”)]
[return: System.Xml.Serialization.SoapElementAttribute(“return”)]
public LocalLBNodeAddressNodeAddressStatistics get_all_statistics()
{ object[] results = this.Invoke(“get_all_statistics”, new object[0]);
return ((LocalLBNodeAddressNodeAddressStatistics)(results[0]));
public System.IAsyncResult Beginget_all_statistics(System.AsyncCallback callback, object asyncState)
return this.BeginInvoke(“get_all_statistics”, new object[0], callback, asyncState);
public LocalLBNodeAddressNodeAddressStatistics Endget_all_statistics(System.IAsyncResult asyncResult)
object[] results = this.EndInvoke(asyncResult);
In NodeAdressMain:
// Get Statistics
NodeAddress.LocalLBNodeAddressNodeAddressStatistics statistics =
NodeAddress.get_statistics(node_list);
NodeAddress.CommonStatistic[] statistic_list = statistics.statistics.statistics;
for (int j = 0; j < statistic_list.Length; j++)
Console.WriteLine(
statistic_list[j].type.ToString() + " : " + build64(statistic_list[j].value)
Plz i need some help and i’m a begginer in c
