Is there a option in f5 to trigger an alert based on scf difference . We recently had an issue with our f5 and the suggestion was to post a query with devcentral to track difference in scf file .
Statement from the support team
“You should be able to generate an SCF with a known good configuration and compare it with one generated whenever changes are made. If you see that changes aren’t being reflected in the new SCF, that would indicate that mcpd hasn’t been updated with the new configuration. This would be a sign that you should contact support:”
Below is the pseudo code that f5 had suggested.
Setup:
Generate starting SCF
Create custom SNMP trap to alert on script alert log, possibly send an email or whatever alerting function you wish to use.
Script Functions:
On Cron - Generate SCF
Diff against starting SCF
If Diff output is empty
Delete the new SCF
Else
Use Logger to record alert log
Handle the new file as desired
