I found the following awesome command on devcentral that creates a file named commands.sh that contains all of the tmsh commands needed to modify the 3rd octet of every VIP on the unit:
echo '!/bin/bash' > /shared/commands.sh; tmsh list ltm virtual destination | tr '\n' ' ' | sed 's/ \+/ /g;s/ltm virtual/\ntmsh modify ltm virtual/g;s/nation 10\.23\.206/nation 10.23.207/g' >> /shared/commands.sh; chmod 755 /shared/commands.sh
What I need is a much simpler version of this command that will create a file named commands.sh that contains all of the tmsh commands needed to re-create all of the nodes on an existing unit, on a brand new unit. So the result would be:
tmsh create ltm node address tmsh create ltm node address tmsh create ltm node address etc…
I know there are easier ways to do this, like copying the node portion of the existing config and pasting it into the new config, but I have my reasons for wanting to do it the above way that I won’t go into. Any help is much appreciated.
Correction:
etc…
ugh! Why can’t I edit my post? I click save and nothing happens.
etc...
tmsh list ltm node | tr '\n' ' ' | sed 's/ \+/ /g;s/{//g;s/}//g;s/ltm node/\ntmsh create ltm node/g' >> create_nodes.sh
!/bin/bash
echo " Create and configure Nodes "
echo ""
echo " Suppresion d'un node"
tmsh delete ltm node N1-HTTP
echo "Create Nodes with default Monitor"
tmsh create ltm node N1-HTTP address @IP-NODE1 monitor default
tmsh create ltm node N2-HTTP address @IP-NODE2 monitor default
echo "Suppresion d'un node"
tmsh delete ltm node N3-HTTP
echo "Create node with HTTPS Monitor"
tmsh create ltm node N3-HTTP description Node HTTPS address @IP-NODE3 monitor https_443
echo "Edit node monitor"
tmsh modify ltm node N3-HTTP monitor default
echo "Show Node"
tmsh list ltm node state
echo "Show Node with metadata ratio session"
tmsh list ltm node metadata ratio session
echo "Show Node 1 details"
tmsh list ltm node N1-HTTP session
