Hi!
When trying to do federated login from ADFS to BigIP as IdP, I am getting a 504 response from the BigIP.
Process:
1) I log into my web app, that redirects to ADFS.
2) On the ADFS, I choose the Home realm (BigIP)
3) Redirect to BigIP /saml/idp/profile/redirectorpost/sso
4) Redirect to BigIP /my.policy
5) Log in, I see AD login successful and session variables assigned.
6) Response from my.policy carries a POST form.
7) POST request submitted to BigIP /saml/idp/profile/redirectorpost/sso
-- response is 504 with no content.
I am new to APM, so I may not really know where exactly to look, however browsing both APM reports and System logs turned up nothing useful or indicative.
OK, solved this on my own
APM reports are pretty tight with useful information, however APM logs available in /var/log/apm give an abundance of information.
In my case, these were the hurdles to jump when getting BigIP IdP to play with ADFS 3.0 SP:
1) BigIP External SP Connector:
Security Settings / Authentication Request sent to this device by SP / Will be signed: NO
Security Settings / Assertion sent to SP by this device: Must be signed, or must be encrypted, or both. Certificate settings: use ADFS Token Decrtyption/Encryption certificate
Endpoint Settings / Relay state needs to be filled. https:///adfs/ls/
2) BigIP IdP service - add a UPN claim. ADFS requires it, else it will refuse to work.
3) ADFS Claims Provider trust (advanced): use SHA 1 algorithm for hashing
Hope this helps anybody else on this path…
Regards,
Z
