SAML Attributes require String type
I am doing a SAML Integration with Tableau Server.
Actually Tableau is unable to read my username attribute, because it is missing
xsi:type="xs:string"
Their documentation say: “You must configure the IdP to return an assertion that includes the username attribute in the saml:AttributeStatement element. The assertion’s attribute type must be xs:string (it should not be typed as xs:any).”
They required this:
saml:AttributeStatement>
    <saml:Attribute Name="username" NameFormat="urn:oasis:names:tc:SAML:2.0:attrname-format:basic">
    <saml:AttributeValue xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="xs:string">
          user-name
    </saml:AttributeValue>
    </saml:Attribute>
  </saml:AttributeStatement>
</saml:Assertion>
and for now F5 SAML return this:
 <saml2:AttributeStatement>
      <saml2:Attribute xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion"
               Name="username"
        <saml2:AttributeValue xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion">user-name</saml2:AttributeValue>
      </saml2:Attribute>
    </saml2:AttributeStatement>
  </saml2:Assertion>
Another example is using OKTA as an IDP , it return this and it works:
<saml2:AttributeStatement xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion">
      <saml2:Attribute Name="username"
               NameFormat="urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified"
        <saml2:AttributeValue xmlns:xs="http://www.w3.org/2001/XMLSchema"
      </saml2:Attribute>
How can I do this with F5, we are using Big-IP release 14
I need to find a way to add
to the username attribute.
I do not see any way to do this from the SAML Attributes in Edit IDP Service
Thank,
You can rewrite the assertion using an iRule. The rule below might work for you.
when ACCESS_SAML_ASSERTION {
        set assertion [ ACCESS::saml assertion ]
        set new_assertion [ string map [list "<saml2:AttributeValue xmlns:saml2=\"urn:oasis:names:tc:SAML:2.0:assertion\">" "<saml2:AttributeValue xmlns:saml2=\"urn:oasis:names:tc:SAML:2.0:assertion\" xsi:type=\"xs:string\">"] $assertion ]
        ACCESS::saml assertion $new_assertion
