“Required request body is missing: public org.springframework.http.ResponseEntity"
Hi All,
some days ago I upgarded F5 at 15.2.1. version, everything works fine exepct one application, in detail whene I use tbhe application I receive the  error message see file that I attached .
In the version before when i use the application I have no error.
Is it possible to fix it by an Irule ?
Many thanks in advanced.
Regards,
Paolo
possibly…what version did you move from, and what defaults in your profiles might have changed? Do you have a capture of clientside and server side request traffic for the issue at hand?
Hi Jason,
I moved from 12.1.2  to 15.1.2 version.
You need to know that I upgraded both lb  withouth modify profiles configurations.
I have done some analisys and it seems that the error appaers because the F5 does not pass information to the application.
Many thanks in advanced for tyour coop.
Rgds
