Hi folks
I am really diasappointed
F5 made 17.1.3.2 release with several bugs
public patch .0.14.32 for 17.1.3.2 to fix one web interface problem
but critical for me bug myF5 need request EHF from support to fix.
Am I last person who have 17.1.3.2 in production ?
Why not to fix errors in one another public EHF ?
iRule bug affect all 17.1.3.2 users
Why haven’t you upgraded to 17.5.1.6 if you want less vulnerabilities
myF5 ? Did you check with them about a fix on 17.5.x as if you are going to have to upgrade anyway better go higher?
Also I saw that this was released a month ago and not wanting eng hotfix if you have the F5 licensed should not be an issue as F5 usually releases minor versions for more than one issue.
Ok. Finally in June F5 release public Hotfix-BIGIP-17.1.3.2.0.39.32-ENG.iso
So the shame is over then
