I’m using the iControl Java lib and am getting “Read Access Denied” errors.
public class F5Test implements Credentials {
private Interfaces f5Interface = new Interfaces("my-lb.example.com", 443, UNAME, PSWD);
public static void main(String[] args) {
F5Test test = new F5Test();
test.test();
void test() {
try {
f5Interface.getManagementPartition().set_active_partition("my-partition");
String[] rules = {
"irule_my_rule"
String[][] md = f5Interface.getLocalLBRule().get_metadata(rules);
for(String[] mds : md) {
for(String metadata : mds) {
System.out.println(metadata);
} catch (RemoteException e) {
e.printStackTrace();
} catch (Exception e) {
When I run this I get:
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server
faultSubcode:
faultString: Exception caught in LocalLB::urn:iControl:LocalLB/Rule::get_metadata()
Exception: Common::OperationFailed
primary_error_code : 17238051 (0x01070823)
secondary_error_code : 0
error_string : 01070823:3: Read Access Denied: user (zharvey) type (rule metadata)
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:Exception caught in LocalLB::urn:iControl:LocalLB/Rule::get_metadata()
at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder.java:222)
at org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder.java:129)
...rest of stack trace omitted for brevity
I have confirmed that the iRule “irule_my_rule” is defined inside “my-partition” and our IT staff confirms I have full r/w permission for it. Am I using the API incorrectly or is this an F5 config issue?
