Problem this snippet solves:
QuickMon is a small monitoring tool that provides instantaneous information regarding the network and application infrastructure.
It is configured to collect informations from BIG-IP devices using SNMP. Supported information in the current version are:
- General Information
- System CPU Usage
- System CPU Cores
- CPU Core Usage
- System Memory Used
- Network Interfaces
- Interface Traffic
- Packets Rate
- Errors
- Total Throughput
- Total Connections
- Total Connections Rate
- SSL Transactions Rate
- SSL Throughput
- HTTP Requests Rate
- LTM - Virtual Servers
- Total Connections
- Connections Rate
- Traffic
- LTM - Pools
- Total Connections
- Connections Rate
- Traffic
- LTM - Nodes
- Total Connections
- Connections Rate
- Traffic
It’s also possible to add custom items through the user’s template support.
QuickMon is an open-source project hosted on GitHub. The source code, updates and more information can be found by accessing the project URL: GitHub - renatoferreirarenatoferreira/quickmon: Network troubleshooting tool. · GitHub
Code :
https://github.com/renatoferreirarenatoferreira/quickmon/releases
