Problem with IP Forwarding Virtual server
I recently created a new HA pair. One unit has been running for a year or so as a standalone. So I created a new unit then built the HA pair, synched the configuration and everything is happy. However, if I failover to the “new” unit in the HA pair no IP forwarding traffic seems to pass through the unit in either direction. I can’t ping through or establish any connections from the nodes on the internal side - web servers. From the external side I can’t ping BUT if I connect to the HTTP VIP it works. So I know I can establish a direct connection to the web server through the VIP. It just appears that the forwarding traffic doesn’t work. I have verified that the web server/node is getting the arp entries after the failover so it knows where to send traffic.
A quick tcpdump from the web server shows the ICMP getting into the F5 but never getting a response.
If I fail back to the “original” unit then things work fine with no issues.
I can ssh to the “non-working” unit and can ping internal and external ip addresses, all my nodes, etc… So i know that network connectivity is good.
The configuration is pretty basic so I’m a bit lost on what could be happening.
Anyone have any ideas of something to check?
thanks
Do you have MAC Masquerading configured? some equipment will not accept gratuitous arps, and it makes failover kind of clunky.
I don’t at this time. I have another HA pair on my network running an older 11.2.1 version that works fine. I read a little about the MAC setting. I should probably investigate it further just to see.
thx
Hi, what’s the outcome from this? Curious if failover didn’t work because MAC Masquerading was disabled.
thanks,
Have you got the root cause of this issue ?
