Problem with http/https connection
Hello all,
i have created new VIP with below config.
virtual r_vs_sitcom_lso_24105 {
pool pool_sitcom_lso_24105
destination 10.155.65.64:24105
ip protocol tcp
persist profile_sitcom_persist
profiles {
http {}
tcp {}
vlans INTERCO enable
[root@STG1F5LDB01:Active] config b pool pool_sitcom_lso_24105 list
pool pool_sitcom_lso_24105 {
monitor all sitcom_http_24105
members {
10.155.62.112:24105 {}
10.155.62.113:24105 {}
However when i tested, i get below output.
The URL fail with “Error 101 (net::ERR_CONNECTION_RESET) : The connection was reset.”
http://10.155.62.112:24105 works
http://10.155.62.113:24105 works
is associated with VIP 10.155.65.64:24105 in DNS.
direct connection to server is working well, but via F5 does not work well.
please suggest
profile persist profile_sitcom_persist {
defaults from source_addr
mode source addr
timeout 1800
profile info…
Where do you see that error?
What happens if you try http://10.155.65.64:24105?
Does the server have a route back to the client IP that’s pointing at the F5? I suspect not, you may need to configure an SNAT on the VS. Automap would do just to confirm that’s the issue.
Thanks Steve..SNAT works well..
Cool, glad to hear it.
