Problem this snippet solves:
This sample PowerShell script illustrates how to use the methods in the LocalLB::Pool interface to get and set the Ratio and Priority for a Pool Member.
Note, this example uses the new pool member methods in the LocalLB Pool interface introduced in BIG-IP v11.0
Code :
# The contents of this file are subject to the "END USER LICENSE AGREEMENT
# FOR F5 Software Development Kit for iControl"; you may not use this file
# except in compliance with the License. The License is included in the
# iControl Software Development Kit.
# Software distributed under the License is distributed on an "AS IS"
# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
# the License for the specific language governing rights and limitations
# under the License.
# The Original Code is iControl Code and related documentation
# distributed by F5.
# The Initial Developer of the Original Code is F5 Networks, Inc.
# Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2012
# F5 Networks, Inc. All Rights Reserved. iControl (TM) is a registered
# trademark of F5 Networks, Inc.
# Alternatively, the contents of this file may be used under the terms
# of the GNU General Public License (the "GPL"), in which case the
# provisions of GPL are applicable instead of those above. If you wish
# to allow use of your version of this file only under the terms of the
# GPL and not to allow others to use your version of this file under the
# License, indicate your decision by deleting the provisions above and
# replace them with the notice and other provisions required by the GPL.
# If you do not delete the provisions above, a recipient may use your
# version of this file under either the License or the GPL.
param (
$BIGIP = $null,
$User = $null,
$Pass = $null,
$Pool = $null,
$Member = $null,
$Ratio = $null,
$Priority = $null
# function Show-Usage
function Show-Usage()
Write-Host @"
Usage: PoolMemberRatioPriority.ps1 BIGIP User Pass Pool Member Ratio Priority
Examples
.\PoolMemberRatioPriority.ps1 -BIGIP bigip -User user -Pass pass : list pools
.\PoolMemberRatioPriority.ps1 -BIGIP bigip -User user -Pass pass -Member ipport : list pool members
.\PoolMemberRatioPriority.ps1 -BIGIP bigip -User user -Pass pass -Member ipport -Ratio 5 : set member ratio to 5
.\PoolMemberRatioPriority.ps1 -BIGIP bigip -User user -Pass pass -Member ipport -Priority 3 : set member priority to 3
exit;
function Do-Initialize()
if ( (Get-PSSnapin | Where-Object { $_.Name -eq "iControlSnapIn"}) -eq $null )
Add-PSSnapIn iControlSnapIn
$success = Initialize-F5.iControl -HostName $BIGIP -Username $User -Password $Pass;
return $success;
function Parse-AddressPort()
param($Value);
$tokens = $Value.Split(":");
$r = New-Object iControl.CommonAddressPort;
$r.address = $tokens[0];
$r.port = $tokens[1];
$r;
function Get-Pools()
(Get-F5.iControl).LocalLBPool.get_list();
function Get-PoolMembers()
param(
$Pool = $null
$MemberListAofA = (Get-F5.iControl).LocalLBPool.get_member_v2( @($Pool) );
$MemberListA = $MemberListAofA[0];
$MemberListA;
function Get-PoolMemberDetails()
param(
$Pool = $null,
$Member = $null
$AddrPort = Parse-AddressPort $Member;
$RatioAofA = (Get-F5.iControl).LocalLBPool.get_member_ratio(
@($Pool),
@( @($AddrPort) )
$PriorityAofA = (Get-F5.iControl).LocalLBPool.get_member_priority(
@($Pool),
@( @($AddrPort) )
$ratio = $RatioAofA[0][0];
$priority = $PriorityAofA[0][0];
"Pool '$Pool' member '$Member' ratio '$ratio' priority '$priority'";
function Set-PoolMemberDetails()
param(
$Pool = $null,
$Member = $null,
$Ratio = $null,
$Priority = $null
if ( $null -ne $Ratio )
(Get-F5.iControl).LocalLBPool.set_member_ratio(
@($Pool),
@( @($AddrPort) ),
@($Ratio)
if ( $null -ne $Priority )
(Get-F5.iControl).LocalLBPool.set_member_priority(
@($Pool),
@( @($AddrPort) ),
@($Priority)
# Main Application Logic
if ( ($BIGIP -eq $null) -or ($User -eq $null) -or ($Pass -eq $null) )
Show-Usage;
if ( Do-Initialize )
if ( $Pool -eq $null )
# List Pools
Get-Pools;
elseif ( $Member -eq $null )
# List Pool Members
Get-PoolMembers -Pool $Pool;
elseif ( ($Ratio -eq $null) -and ($Priority -eq $null) )
# List Pool Member Details
Get-PoolMemberDetails -Pool $Pool -Member $Member;
else
# Set Ratio and/or Priority
Set-PoolMemberDetails -Pool $Pool -Member $Member -Ratio $Ratio -Priority $Priority;
else
Write-Error "ERROR: iControl subsystem not initialized"
