Problem this snippet solves:
There currently isn’t a way to directly access which pools are referenced in iRules and which iRules reference pools. This sample solves that by pulling down all pools and rules and searches the content of the rules for a reference of each pool. It then presents two tables: The first shows all the rules with a listing of the pools that are referenced in them. The second shows all the pools with a listing of all rules they are referenced in.
Code :
#!/usr/bin/perl
# The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5
# Software Development Kit for iControl"; you may not use this file except in
# compliance with the License. The License is included in the iControl
# Software Development Kit.
# Software distributed under the License is distributed on an "AS IS"
# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
# the License for the specific language governing rights and limitations
# under the License.
# The Original Code is iControl Code and related documentation
# distributed by F5.
# The Initial Developer of the Original Code is F5 Networks,
# Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks,
# Inc. All Rights Reserved. iControl (TM) is a registered trademark of F5 Networks, Inc.
# Alternatively, the contents of this file may be used under the terms
# of the GNU General Public License (the "GPL"), in which case the
# provisions of GPL are applicable instead of those above. If you wish
# to allow use of your version of this file only under the terms of the
# GPL and not to allow others to use your version of this file under the
# License, indicate your decision by deleting the provisions above and
# replace them with the notice and other provisions required by the GPL.
# If you do not delete the provisions above, a recipient may use your
# version of this file under either the License or the GPL.
#use SOAP::Lite + trace => qw(method debug);
use SOAP::Lite;
use MIME::Base64;
# Validate Arguments
my $sHost = $ARGV[0];
my $sPort = $ARGV[1];
my $sUID = $ARGV[2];
my $sPWD = $ARGV[3];
my $sProtocol = "https";
if ( ("80" eq $sPort) or ("8080" eq $sPort) )
$sProtocol = "http";
if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
die ("Usage: PoolsInRules.pl host port uid pwd\n");
# Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials-->
return "$sUID" => "$sPWD";
$Rule = SOAP::Lite
-> uri('urn<!--:iControl:LocalLB/Rule')-->
-> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
eval { $Rule->transport->http_request->header
'Authorization' =>
'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')-->
$Pool = SOAP::Lite
-> uri('urn<!--:iControl:LocalLB/Pool')-->
eval { $Pool->transport->http_request->header
'Authorization' =>
&getAllPoolsInRules();
# checkResponse
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
exit();
# getAllPoolsInRules
sub getAllPoolsInRules()
#print "Querying pool list...\n";
$soapResponse = $Pool->get_list();
&checkResponse($soapResponse);
my @pool_list = @{$soapResponse->result};
$soapResponse = $Rule->query_all_rules();
my @rule_def_list = @{$soapResponse->result};
&getPoolsInRules(\@pool_list, \@rule_def_list);
&getPoolsInRules2(\@pool_list, \@rule_def_list);
# getPoolsInRules
sub getPoolsInRules()
my ($pool_list, $rule_def_list) = @_;
print "=================================================\n";
print " Rules Pools\n";
print "-------------------------- -------------------\n";
foreach $rule_def (@$rule_def_list)
$i = 0;
$rule_name = $rule_def->{"rule_name"};
$rule_definition = $rule_def->{"rule_definition"};
printf "%25s => ", "$rule_name";
foreach $pool (@$pool_list)
$found = $rule_definition =~ /(pool)\s+($pool)/;
if ( $found )
if ( $i )
print ", ";
print "$pool";
$i++;
print "\n";
# getPoolsInRules2
sub getPoolsInRules2()
print " Pools Rules\n";
printf "%25s => ", "$pool";
$i = 0;
if ( $found )
if ( $i )
print ", ";
print "$rule_name";
$i++;
print "\n";
