pool selection
Hi, is it poossible to implement irule logic below?
By default traffic select Pool1, but it select Pool2 if online pool members of Pool1 below two. If all pool members became available in Pool1, traffic will continue select Pool2.
@_Dmi You can do this with priority group activation in 1 pool rather than having 2 different pools.
I cant use it. The full scenario is
By default traffic select Pool1, but it select Pool2 if online pool members of Pool1 below two. If all pool members became available in Pool1, traffic will continue select Pool2. But then online pool members of Pool2 below two, traffic must come back to Pool1.
Hii
You can try this
set pool_a_members [LB::pool pool_a members]
if { [llength $pool_a_members] > 0 } {
pool pool_a
pool pool_b
or check this post similar
https://community.f5.com/t5/technical-forum/how-to-write-an-irule-to-redirect-traffic-to-different-pool/td-p/84432
Best Regard
I think the iRule below fill meet your requirements.
when CLIENT_ACCEPTED {
    set pri_pool "/Common/pool_a"
    set sec_pool "/Common/pool_b"
    if {[table lookup active_pool] ne ""} {
        if { [active_members [table lookup active_pool]] >= 2 } {
        elseif { $active_pool eq $pri_pool } {
            table replace active_pool $sec_pool indefinite
        else {
            table replace active_pool $pri_pool indefinite
    else {
        table set active_pool $pri_pool indefinite
    pool [table lookup active_pool]
Have fun,
--Niels
