OCSP and Comodo cert
Hi all,
I was wondering if somebody ran into the same issue with OCSP and Comodo issued certs.
Since last week we’re getting “OCSP Check Failed” messages for Comodo issued certificates. We did some tcpdumps to figure out what’s going on and it seems that Comodo OCSP URL requires a host header.
This was the HTTP response to our OCSP request:
Invalid URL
The requested URL "[no URL]", is invalid.
Reference 9.7ce58db.1529652000.5b7f63b
A manually performed check confirmed the issue (we’re on 12.1.2-HF2):
openssl ocsp -issuer comodo-chain-bundle.crt -cert web-certificate.crt -text -url http://ocsp.comodoca.com -no_nonce -verify_other comodo-chain-bundle.crt
OCSP Request Data:
    Version: 1 (0x0)
    Requestor List:
        Certificate ID:
          Hash Algorithm: sha1
          Issuer Name Hash: xxxx
          Issuer Key Hash: yyyy
          Serial Number: zzzz
Error querying OCSP responder
47881717408264:error:27076072:OCSP routines:PARSE_HTTP_LINE1:server response error:ocsp_ht.c:247:Code=400,Reason=Bad Request
By adding a host header to the openssl command we were able to get a successful response:
openssl ocsp -issuer comodo-chain-bundle.crt -cert web-certificate.crt -text -url http://ocsp.comodoca.com -no_nonce -verify_other comodo-chain-bundle.crt -header "Host" "ocsp.comodoca.com"
OCSP Request Data:
    Version: 1 (0x0)
    Requestor List:
        Certificate ID:
          Serial Number: zzzz
OCSP Response Data:
    OCSP Response Status: successful (0x0)
    Response Type: Basic OCSP Response
    Version: 1 (0x0)
    Responder Id: 90AF6A3A945A0BD890EA125673DF43B43A28DAE7
    Produced At: Jun 20 08:45:26 2018 GMT
    Responses:
    Certificate ID:
      Serial Number: zzzz
    Cert Status: good
    This Update: Jun 20 08:45:26 2018 GMT
    Next Update: Jun 27 08:45:26 2018 GMT
    Signature Algorithm: sha256WithRSAEncryption
         ---snippp---
Response verify OK
web-certificate.crt: good
The “web-certificate.crt” is issued by
Issuer: COMODO RSA Domain Validation Secure Server CA, COMODO CA Limited Write review of Comodo
Our “comodo-chain-bundle.crt” contains
Common Name: COMODO RSA Domain Validation Secure Server CA
Issuer: COMODO RSA Certification Authority, COMODO CA Limited Write review of Comodo
Common Name: COMODO RSA Certification Authority
Our implemented OCSP check doesn’t send a host header and we have no issue with certificates issued by other CAs.
Does anybody know a workaround? Can we savely add a host header to our OCSP check without affecting the checks of other certificates?
Any hint is much appreciated. cheers
This is an issue with openssl and is fixed in v1.0.2. See https://github.com/openssl/openssl/issues/1986.
The latest BIG-IP (v13.1.0.7) has openssl v1.0.1l installed.
I have a customer were the OCSP monitoring is not working.
A check with openssl on BIG-IP 16.1.4.2 was not working. As soon I added the host header in the openssl ocsp … command the OCSP response was “good” and not 400 Bad Request.
I also tested this with v17.1.1.2 and it does not work.
So I’m in process of installing v17.1.2.1 now and do some more tests there.
I will come back as soon I have an update here.
