By searching for observed mode we can see the definition “Observed load balancing is ratio load balancing where the ratios are dynamically assigned by the F5 every second based on connection counts.” Wondering is I can see which is the current ratio assigned for the nodes by the Observed mode. The ratio I can see inside the pool is the default and all nodes show the value of 1, in my scenario.
Does anyone knows a command to show the actual ratio assigned to nodes inside a pool with observed mode?
