Hello
anybody have same issue that acces f5 via ssh and gui failed, telnet to port 443 and 22 success
log during ssh
kex_exchange_identification: Connection closed by remote host
Hello
log during ssh
hi, can you send verbose log for ssh connection from client side? e.g. “ssh -l <username> <f5 device> -vv” It seems that kex are changed after upgrade (did you upgrade the system?) and there is no match between client and server side.
i did not upgrade system, few days ago i can access via gui and ssh
the problem solved after change boot location by console
