Hi all, I have a F5 here being setup by the previous F5 administrator.
Our previous webserver was 10.8.6.19 and it was replace by this F5 10.8.10.12 and 10.8.10.14 are the Application server.
I don’t quite understand is that why is the VS is set as the web server IP and not the application server ?
When I check on the firewall, the public IP is pointing to 10.8.6.19 which makes me more confusing.
Ltm::Node: 10.8.10.12 (10.8.10.12)
Status Availability : available
State : enabled
Reason : Node address is available
Monitor : /Common/icmp (default node monitor)
Monitor Status : up
Session Status : enabled
Ltm::Node: 10.8.10.14 (10.8.10.14)
State : enabled
Monitor Status : up
Ltm::Pool: test_pool_15005
State : enabled
Reason : The pool is available
Monitor : test_tcp_15005
Minimum Active Members : 0
Current Active Members : 2
Total Requests : 0
Current Sessions : 0
Ltm::Pool: test_pool_15007
State : enabled
Monitor : test_tcp_15007
Current Active Members : 1
Total Requests : 0
Ltm::Pool: test_pool_https
State : enabled
Monitor : test_tcp_18080
Total Requests : 1484
Current Sessions : 18446744073709551615
Ltm::Virtual Server: test_vs_10080
State : enabled
Reason : The virtual server is available
CMP : enabled
CMP Mode : all-cpus
Destination : 10.8.6.19:10080
Ltm::Virtual Server: test_vs_10081
State : enabled
CMP : enabled
CMP Mode : all-cpus
Destination : 10.8.6.19:10081
Ltm::Virtual Server: test_vs_https
State : enabled
CMP : enabled
CMP Mode : all-cpus
Destination : 10.8.6.19:443
Ltm::Virtual Server: test_vs_stunnel
State : enabled
CMP : enabled
CMP Mode : all-cpus
Destination : 10.8.6.19:10443
