We are finding below error log in our F5 LTM caused by an IRule. Could you please suggest any ideas to isolate the cause of the issue and work on the possible solution?
Error log:
TCL error: /irule <CLIENT_DATA> - buffer error invoked from within “::code”
Hi @Thiyagu , you’ll get more eyes on your question if you provide more details. There is no code for us to evaluate as to why there might be an issue, and no context for why the code is necessary in the first place. That said, I found one match for some of your error wording in the bug tracker:
