Multiple Websites on Single VIP
I have multiple websites which are currently on Microsoft TMG. I want to migrate them to F5. There are multiple URLS hosted on different servers which are running on different ports as well.
I have only one Public IP. I have created pools for different servers and i have applied the certficate on the VIP as well.
All the traffic should be SSL from the client side.
My requirement is
if any user type
https://site1.test.com/ http://site1.test.com/ www.site1.test.com
it should go
https://site1.test.com/arsys
https://site2.test.com/ http://site2.test.com/ www.site2.test.com
it should go
https://site3.test.com/ http://site3.test.com/ www.site3.test.com
it should go
I have created multiple pools and will recall them in the irule.
How can i achieve this. Single VIP with multiple Website which require SSL offload as well as redirection of URL.
I would use two VIPs, one for HTTP and one for HTTPS. On the HTTP VIP you will want to create an iRule that redirects to HTTPS. You can use the built in iRule that exists for this, _sys_https_redirect or somthing like this if you want a 301 if you ever plan to use HSTS:
set my_loc "https://[HTTP::host][HTTP::uri]"
TCP::respond "HTTP/1.1 301 Moved Permanently\r\nLocation: $my_loc\r\nConnection: close\r\nContent-Length: 0\r\n\r\n"
TCP::close
On the HTTPS VIP you will want to create a client SSL Profile for each site and use the “Server Name” field to enable SNI. With SNI you will need to create one of those profiles as the default for legacy clients, but you can also set the default profile to require SNI if you so desire.
TCP::close
I have applied the rules, for default bulitin HTTP to HTTPS and one has mention below ltm rule PROXY_TEST2 { partition REVERSE_PROXY when HTTP_REQUEST { set my_loc “https://[HTTP::host][HTTP::uri]” TCP::respond “HTTP/1.1 301 Moved Permanently\r\nLocation: $my_loc\r\nConnection: close\r\nContent-Length: 0\r\n\r\n” TCP::close } I have created two VIP one for HTTPS and one for HTTP but no luck. i can see the hit on VS and secuirty error page but not able to open the page.
So the redirect sends you from HTTP to HTTPS correctly and you are presented a certificate. Does the certfiicate match what you would expect to be presented? i.e. https://site1.test.com/ is presented the certificate for site1.test.com?
Yesr SSL profile is applied.
But none of the site is opening. Just to know that i didnt recall any pool in the irule or anywhereelse in the config. HOw it will work ???
I just noticed you wanted to account for www in your HTTP-HTTPS redirect so here’s an update example for that irule:
    if {[string tolower [HTTP::host]] starts_with "www."}{
        set host [string range [HTTP::host] 4 end]
    else {
        set host [HTTP::host]
    set my_loc "https://$host[HTTP::uri]"
    TCP::close
The irule for the pool selection on your HTTPS VIP could look something like this:
    switch [string tolower [HTTP::host]] {
        "site1.test.com" {
            pool site1_pool
        "site2.test.com" {
            pool site2_pool
        "site3.test.com" {
            pool site3_pool
        default {
            pool default_pool
Hope this helps.
    else {
    TCP::close
        "site1.test.com" {
            pool site1_pool
        "site2.test.com" {
            pool site2_pool
        "site3.test.com" {
            pool site3_pool
        default {
            pool default_pool
Hope this helps.
you mean to say I will apply two irules to HTTPS VIP, one for the pool and one for the header/www etc. One redirect which will be on the HTTP VIP.
I tried below config but no luck.
ltm virtual VS_RProxy_80 { description VS_RProxy_80 destination 192.168.216.33:http ip-protocol tcp mask 255.255.255.255 partition REVERSE_PROXY profiles { /Common/http { } /Common/tcp { } } rules { /Common/_sys_https_redirect } source 0.0.0.0/0 vlans { RPROXY_EXT_316 } vlans-enabled vs-index 244
ltm virtual VS_RProxy_443 {
description VS_RProxy_443
destination 192.168.216.33:https
ip-protocol tcp
persist {
    Reverse_Proxy_Persistence {
        default yes
profiles {
    /Common/http { }
    /Common/tcp { }
    Reverse_Proxy_Cert {
        context clientside
rules {
    TEST-1
    PROXY_TEST2
source 0.0.0.0/0
source-address-translation {
    type automap
vlans {
    RPROXY_EXT_316
vlans-enabled
vs-index 242
ltm rule TEST-1 {
    "enoclubricants.com" {
        pool ENOCLUBRICANTSPP1
    "enocvettingsiredev.enoc.com" {
        pool ENOCVETTING
    "wrench.enoc.com" {
        pool WRENCH_POOL
    default {
         Use pool attached to virtual - no action required
But still not able to see any web page.
One irule, the top one, for your HTTP VIP to handle to redirects(including accounting for www adn redirecting without it) and one iRule, the second one on the HTTPS VIP for pool selection.
I added a comment above for the previous question. Looking at your config here, do you have one certificate that will cover the three different domains? or do you have three different certificates? You only have one client-ssl profile attached. If you have three different certificates, you will need three different profiles with SNI enable by using the “Server Name” field mentioned in my first comment.
yes i have the certificate which has all websites names and i have recall the exact the same profile in the client ssl profile.
can you try to remove PROXY_TEST2 irule from VS_RProxy_443 virtual server and see if it makes any different?
I have removed the irule only i have only one irule on the HTTPS VIP. but still the same.
when HTTP_REQUEST { switch [string tolower [HTTP::host]] { “enoclubricants.com” { pool ENOCLUBRICANTSPP1 } “enocvettingsiredev.enoc.com” { pool ENOCVETTING } “wrench.enoc.com” { pool WRENCH_POOL } default { Use pool attached to virtual - no action required } } }
can you add some logging?
e.g.
  log local0. "client=[IP::client_addr]:[TCP::client_port] host=[HTTP::host] uri=[HTTP::uri]"
    "enoclubricants.com" { pool ENOCLUBRICANTSPP1 }
    "enocvettingsiredev.enoc.com" { pool ENOCVETTING }
    "wrench.enoc.com" { pool WRENCH_POOL }
    default {
when HTTP_RESPONSE {
  log local0. "client=[IP::client_addr]:[TCP::client_port] pool=[LB::server pool]"
e.g.
    default {
