monitor for non FQDN host
Hello,
I am trying to use an HTTPS monitor for the below url
Where abcd is not FQDN host…
When I use a monitor without Receive string, everything works. But when I use the monitor with a receive string such as moved, 301 or anything else which I see in the response, its not working.
When I curl the pool member curl -v http://1.1.1.1/xyz using the IP.. Its responding and i am using the content from that response itself.
Will the monitor GET /xyz HTTP/1.1\r\nHost: abcd\r\nConnection: Close\r\n\r\n work??
Or I am supposed to leave the host as blank
GET /xyz HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n
Regards
When you send the curl… And it works… Use the exact same request. And place something from the response as the receive string.
If that still fails then, assuming you have access to the HTTPS server keys, use ssldump to snoop the traffic and decode it.
Try this from the command line to better replicate the monitor:
echo -ne "GET /xyz HTTP/1.1\r\nHost: abcd\r\nConnection: Cloechse\r\n\r\n" | nc
/Patrik
