Hello,
Would you please let me know if there is any way to input/create data group in bigup not via the GUI? I am going to create 300+ data group list
Hello,
You can see an article I made a long ago if it helps:
Hello Danielc
You can create external datagroups
Yup as this is one of the things I have shown in the link I provided.
Sorry mate, too many literature for me ![]()
Hello Dario,
I looked at it, it seems for this approach, i will need to create 300+ files for 300+ data group, am I understand this correctly?
Yep, you have to create a file for each datagroup, that’s the key. But I don’t understand why you need to create 300+ datagroups instead of a few datagroups with many records. Could you clarify what your approach is?
I am doing access control based on different objects, I have 300+ different objects need to check access control of 300+ group of IP address. I am still thinking should I do this via ansible.
Then just check the link I proved as I am using Ansible for this task ![]()
Thanks, I already solved this problem by myself and I have already created 300+ data groups.
I just wonder why nobody let me know I can create data group by tmsh command…
create /ltm data-group internal d1051_ip_dc type ip records add { 172.2.3.1/32 {} 172.2.3.2/32 {} }
With this command I just able to use excel to lookup the IP address and automatically generate 300+ tmsh commands in one go…then hola…solved.
