LTM VS padding payload response with whitespaces and asterisk
I have an application that talks to an old OpenVMS system, which was problematic in permanently closing TCP connections. To resolve this issue, I have put a BIG-IP Virtual Server in between them, so the message flow is now:
webMethods --> BIG-IP LTM --> OpenVMS server
This has resolved the TCP connection issue, and I thought everything was good.
However, the application sends XML, and the VMS system responds with the XML payload.
For some reason, BIG-IP is padding the response with lots whitespaces and one asterisk *
The webMethods server does not expect the * in the response and fails to process the response to the client (who originally sent the XML).
So why is BIG-IP adding the * to the response payload?
I’ve included a WireShark trace image, which shows the BIG-IP VS 10.1.4.170 responding to the webMethods server 10.1.4.225, with the payload, including lots of HEX 20 (whitespace) and one * at the end.
My VS configuration uses Type Standard with all the defaults, except, of course, that I’ve configured the Destination Address and Service Port (3012) and added a Pool.
The closes F5 article I have found is this one:
K44201501: BIG-IP is padding HTTP response with additional whitespaces
However, I don’t have Analytics configured on this VS, and I don’t have Application Visibility and Reporting (AVR) provisioned. So, this doesn’t apply, but it’s a similar issue.
do you have http profile assigned into the vserver?
and change decoding to HTTP in tcpdump so we can see the http headers and payload.
Hi zamroni777
Thanks for your reply.
My post took a few days to publish, and I was trying to find a way to delete my post.
A Developer informed me of this issue (padding with many whitespaces and one asterisk ), and I could see the behaviour in the TCPdump. However, when doing a TCPdump on the OpenVMS server and bypassing BIG-IP, I saw the same behaviour, so BIG-IP is not adding this asterisk; it’s always been there. I compared the traces, and they were the same, so I was misinformed by the Developer.
Thanks for taking the time to respond.
