On 10.2.4 when I look at the statistics for a VIP I see the current number of connections as well as the maximum and Total, these two last values are measured against what time frame? Is it Maximum connections in an hour or day or since uptime?
Thanks for your help, Juan.
These values should reflect total and maximum values from the last time the statistics were manually reset.
Is there a way to figure out when the statistics where reset?
Thanks.
I could be wrong, but I don’t believe that information exists.
Thanks for your responses Kevin.
