Load Balance
Hi Everyone Is that possible to load balance between two virtual servers ?
I have just tested this by creating 2 VS and first checking that they were healthy and responded to http.
After that I added them both to a test pool with each VIP as a new node and they will not pass a simple http health check.
This is all within the same route domain. If you placed the pool members(your two VS) in a separate route domain I am sure this would then work, as the f5 is then just answering requests for clients outside its own network which is a normal operation anyways.
