LIVESTREAM: Copy That! A Packet Duplication Refresh
This one’s been broken for a while — the original iApp, though popular, isn’t even downloadable, and the zipped version that’s been floating around stopped loading on supported BIG-IP versions entirely.
In this stream, Jason Rahm will walk through the update that gets it working again: full IPv4/IPv6 support, compatibility across all currently supported BIG-IP versions, and coverage for multiple duplication use cases.
We’ll go through what’s included in the release:
* The iApp template itself
* An example application service config via tmsh commands
* An IPv4/IPv6 test harness to validate against real use cases
If you’ve ever tried to pull this codeshare entry and hit a wall, this is the fix. Join Jason live, ask questions, and grab the files when we’re done.
Check out @JRahm’s livestream on-demand here:
