we are using APM for SAML authentication. Domain joined machines should authenticate transparently with Kerberos, users without the ability to use Kerberos (non domain joined, Firefox without negotiate-settings) should receive a form to login.
Kerberos works fine, but users with non domain joined machines receive a browser authentication prompt and “Authentication required to access the resources.”.
Does anybody has set up such a scenario? Any help is appreciated.
I don’t immediately see how it’s possible to tell if a PC is able to authenticate without asking it via a 401, which produces a browser auth pop-up. Is there anything in the initial HTTP request that you can use to tell this class of clients from the other class of clients?
Well, perhaps you could use Group-Policy IEM tool to modify the User-Agent and show the 401 to only those guys via some simple VPE logic? But they would have to use only IE, unless there is some way to do this with Firefox to a group of PCs.
Hi Lucas, thanks for your response. I already thought about changing the User-Agent so that I can check for this header. For the moment, I could live with the 401 prompt, when I can display the auth form after canceling the 401 prompt. But no matter what I do, I receive “Authentication required to access the resources.”, when Negotiate is enabled in the 401 agent.
One possibility is to combine an IP address check and a client check to say “if the client is internal and running Internet Explorer, then they can probably do Keberos; otherwise, show the web form”. For failed 401 returning “Authentication required to access the resources.”, I think that must be a bug -- if the 401 fails, it should follow the failure branch to e.g. web form.
Sorry, it’s not a bug, but is not desirable/expected behaviour either. When APM sends the 401 Unauthorized, the HTTP response content is the error message defined in the APM HTTP 401 Response block. This defaults to “Authentication required to access the resources.”. Instead we would want it to return something that caused the client and APM to advance down the fallback path, perhaps like an auto-submit form that caused the fallback path to be executed. I have submitted bug C2012278 to request such an enhancement to the HTTP 401 Response block.
It should advance if the client issues a POST to my.policy. A GET May also do it but haven’t tested that in this context. Maybe a bit of JavaScript. Let us know the ID number you get from support, it should be 6 digits.
Hi all -- I was able to get a workaround for this from F5 support, which seems to do the right thing. Quoting from the F5 support response: The setup involves checking for the session variable “session.logon.last.authparam”. This variable gets set when the client is supporting “Negotiate”, it is not set when the client supports “Basic”. The necessary steps are listed below: - add “Variable Assign” before “HTTP 401 Response”: “session.logon.last.authparam = return {}” (set session variable “session.logon.last.authparam” to blank) - configure “HTTP 401 Response” - “HTTP Auth Level”: “negotiate” - “HTTP response message”: “” - add “Special_Basic” branch rule: “expr {[mcget {session.logon.last.authparam}] == “”}” (this has to be placed ABOVE the “Negotiate” branch) Now when the client is not supporting Negotiate it goes down the “Special_Basic” branch. I tried it and the result looked to be as expected. If the user is prompted for Kerberos and Kerberos fails then the failure path (designated by the Special_Basic branch) is taken.
Hi Evan, Alternatively, instead of adding the variable assign and using the Special_Basic branch rule, you can try this: - configure “HTTP 401 Response” - “HTTP Auth Level”: “negotiate” - “HTTP response message”: - For the “Negotiate” branch change the default expression to: expr { [mcget {session.logon.last.authtype}] == “Negotiate” && [mcget {session.logon.last.authparam}] != “” }
Hi, Did the solution provided by Evan and Saravanan solve your issue? I have the same need (kerberos for domain computers, SAML for others) and this is really helpful for all others to know if you got a solution. I tried the solution on my lab successfully but it’s better to know if you validate for production users. Stanislas
Just wanted to say thank you Saravanan as your solution worked for me. Also wanted to note that although the workaround posted by Evan did work I was still having a browser login prompt when using IE11 but it worked fine on Chrome.
The solution works but I still have Firefox prompting for credential first. If I cancel it switch back to Kerberos. Any way to force Firefox to use Kerberos prior to basic auth ?
In order to have this work on firefox I had to go to about:config > search for network.negotiate-auth.trusted-uris and add the site you are trying to access. This resolved any prompts I had on firefox.
Further to my investigation with debug I found following line:
bigip debug apmd[16352]: 01490000:7: memcache.c func: “mc_convert_session_var_to_mc_key()” line: 2564 Msg: Converted Var: session.logon.last.authparam to Session Var tmm.session.fa70bd95.session.logon.last.authparam
It assigned variable to session.logon.last.authparam when I am trying to access URL from outside with session variable as shown above.. so there is no way branch rule in 401 HTTP response will fallback… because session.logon.last.authparam}] != “” will always have variable and it will go to kerberos Auth.
Hey AN, are you still having issues with this functionality? I am working on an issue right now where IE and Chrome WERE functional, but have stopped working. What we’ve noticed is that the authorization window is still presented, but we can just cancel it, and authentication is successful. It may be related to a Microsoft bug MS16-119. Can you attempt to cancel the login and see if that works?
I don’t have a answer for you but wanted you to know I originally reported this as working. However just had a report today that when I have a non domain joined computer connected to our network the browser will prompt for username and password. You have the configuration the same as I do so appears to be an issue.
I can also confirm what Chris said if I cancel the browser login prompt I am then taken to my F5 login page and have no issues getting to allow ending.
