I need to create a monitor for our share point environment.
I first tried with the built-in HTTPS monitor, but it gave a 401 error. After some investigation it seems there is an issue if the service is using NTLM and I was recommended to use an external monitor.
With the information I found here I created the following script:
!/bin/sh
This script expects the following Name/Value pairs:
URI = the URI to check
USER = username
PASSWORD = password
RECV = the expected response (case sensitive)
remove IPv&/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
IP=`echo ${1} | sed 's/::ffff://'`
PORT=${2}
PIDFILE="/var/run/`basename ${0}`.${IP}_${PORT}.pid"
kill of the last instance of this monitor if hung and log current pid
if [ -f $PIDFILE ]
then
echo "EAV exceeded runtime needed to kill ${IP}:${PORT} $PIDFILE" | logger -p local0.error
kill -9 `cat $PIDFILE` > /dev/null 2>&1
fi
echo "$$" > $PIDFILE
send request and check for expected response
if [ $PORT -eq 443 ]
then
curl -kfNS --ntlm --user ${USER}:${PASSWORD} https://${IP}${URI} | grep "${RECV}" 2>&1 > /dev/null
else
curl -kfNS --ntlm --user ${USER}:${PASSWORD} http://${IP}:${PORT}${URI} | grep "${RECV}" 2>&1 > /dev/null
fi
mark node UP if expected response was received
if [ $? -eq 0 ]
then
Remove the PID file
rm -f $PIDFILE
echo "UP"
else
Remove the PID file
rm -f $PIDFILE
fi
exit
Currently only using 443 so it on it will only use the first curl command, but wanted it able to handle both and I had some issue when I tried to use the second command.
The curl command works fine from the F5 cli and if I use “run /util test-monitor intranet_sharepoint_monitor_ext address 10.xxx.xxx.xxx port 443” from tmsh it correctly marks the nodes as up or down.
If do the test from the LTM Monitor I get “No successful responses received before deadline” if I try it on the share point that uses NTLM, if I try it on another share point that doesn’t use NTLM it works fine.
Why would it work with the test-monitor command but not with the actual monitor in the GUI, shouldn’t they be the same?!
Anyone have any suggestions on what I could do to solve this?
Have checked so it doesn’t contain any windows characters and I have checked so that file located in /config/filestore/files_d/Common_d/external_monitor_d/ has the correct permissions.
