We are trying to protect an OWA365 portal with XC, but some requests with NTLM authentication show an Error 503 - Service Unavailable message in XC.
I think that is the NTLM auth process because when try the same HTTP GET with “Authorization: Basic” it works fine.
curl -v https://autodiscover.example.com/autodiscover/autodiscover.xml -H “Authorization: Basic ZG9tYWluXHVzZXI6UHJ1ZWJhc2RlcGFzc3dvcmQ=”
< HTTP/2 200<br>< cache-control: private<br>< content-type: text/xml; charset=utf-8<br>< request-id: 00000000-0000-0000-0000-000000000000<br>< server: volt-adc<br><<br><?xml version="1.0" encoding="utf-8"?><br><Autodiscover xmlns="http://schemas.microsoft.com/exchange/autodiscover/responseschema/2006"><br> <Response><br> <Error Time="20:00:00.0000000" Id="000000000"><br><br>
But the browser always fails. First, it responds with a 401 HTTP code. After sending the credentials, XC shows a 503-03 error: ‘Service unavailable’.
method: GET<br>host: autodiscover.example.com<br>req_path: /autodiscover/autodiscover.xml<br>req_body: —<br>api_endpoint: UNKNOWN<br>scheme: https<br>rsp_code: 503<br>rsp_code_details: upstream_reset_before_response_started{remote_reset}<br><br><br>
Do F5-XC have an OWA template or something about the NTLM user portal?
