Is this configuration issue or key issue
Hi F5 was activated with VE-Trial Registration key days ago. But due to some reason, the F5 show unlicensed status after bootup. When I use the same Reg Key to activat the same F5, it shows the below message. I do not know if this is Key issue or registration server issue. the internet is alway good. Any suggestion? Thanks
Hi  @davidy2001  ,
      If this license was working with you before , you may booted up from another bootlocation other than the first used one.
-at all , try to Activate your license manually not Automatically , maybe you have issue with internet connection with F5.
Follow the steps on this Video but with manually method :
or
Follow this KB :
Regards
@Mohamed_Ahmed_Kansoh  Right, thanks
