You cannot export all HTTP captured transactions from BIG-IP Analytics in bulk. For offline analysis, use packet capture or iRules logging as alternatives.
@wlopez - were you able to locate an iRule for logging that?
If so…would love to see it.
If not…you might check out or newly released F5 AI Assistant; I haven’t used it myself but the word is it can help generate iRules (or analyze existing ones, or provide contextual help for existing ones).
