I have an issue with Bitbucket versions where XFF is sent differently depending on the direction of traffic between versions. I am sure other apps have this issue as well. Bitbucket versions ( v7.2.5 --> v8.19.3 )
Can the XFF type case-sensitivity be controlled based on direction. (Right side is a mixed up standard and all upper-case versus the left side is all lower-case.
