Hi All,
I am trying to create an iRule that will match certain URIs against a data-group to decide which pool to send it to and then if no matching URI inspect the header and check against another data-group.
I am trying to make it dynamic enough to be able to be reused in multiple environments and may have to change from using [HTTP::path] to include the VIP port number as there may be multiple virtuals on the same IP/hostname for streams matching on the same path but sent to a different pool.
if { [class match [string tolower [HTTP::path]] starts_with dg_uri_pool_redirect] } {
pool [class lookup [HTTP::path] dg_uri_pool_redirect] }
elseif { [HTTP::header exists remote.contenttype] and [HTTP::header remote.contenttype] equals dg_header_pool_redirect } {
pool [class lookup [HTTP::header remote.contenttype] dg_header_pool_redirect]
Apart from adding the hostname and path in your datagroup, you could use other datagroups to handle that… Untested, but perhaps something similar to this:
set hostLower [string tolower [HTTP::host]]
set pathLower [string tolower [HTTP::path]]
Use a datagroup matched on the host name that will give you the name of another datagroup to use to look up the pool redirect
if { [class match $hostLower starts_with dg_host_dg_lookup] } {
set dgName [class match -value $hostLower starts_with dg_host_dg_lookup]
Now check the correct datagroup for the path
if { [class match $pathLower starts_with $dgName] } {
pool [class lookup $pathLower $dgName]
return
If that didn't work, check for the header value
if { [HTTP::header exists remote.contenttype] && [HTTP::header remote.contenttype] equals dg_header_pool_redirect } {
return
You’d need to add additional data-groups for each host (which includes the hostname:port)
