iRule to allow developers to test specific pool members
I’m new to iRule development, so I apologize if I’m asking a silly question. My department manages the F5 infrastructure, but the resource nodes are managed by multiple internal customers. I have customers who would like to be able to test individual nodes on specific VSs that do not have persistence enabled. I’ve seen a few posts which seem to mention ways to do this, but I haven’t been able to get it to work yet. I’ve tried variations of the following code without success:
    Check the requested URI
   switch -glob [string tolower [HTTP::path]] {
      "/persist1*" {
          Direct traffic to pool member 1
        persist source_addr
    session add source_addr [IP::client_addr] 10.75.65.55 3600
      "/persist2*" {
          Direct traffic to pool member 2
        persist source_addr
    session add source_addr [IP::client_addr] 10.75.65.56 3600
      default {
/persist1 and /persist2 do not exist. My thinking was that I could use that as a switch to drive the switch logic, but I’m sure I’m doing something wrong. Ideally, the customer would like to send a string that sets persistence to a selected node for an hour to allow them to perform testing against that node. Has anyone done this before?
Thanks in advance for any help
You had better to use cookie persistence instead. Here is an codeshare example that may be useful :
https://devcentral.f5.com/codeshare?sid=613
you can use the following irule:
when CLIENT_ACCEPTED {
    set default_pool [LB::server pool]
    set target_member [URI::query [HTTP::uri] server]
    if {!($target_member eq "")} {
        pool $default_pool member $target_member
        HTTP::uri [string map -nocase [list "&server=$target_member" "" "?server=$target_member" "" ] [HTTP::uri]]
Then, the developer may append parameter server=1.2.3.4 for the first request, then the default persistence profile will be used to persist for next requests.
