irule help
Hello Team,
I am looking for irule for the below scenario.
  1. https://www.example.com/user1
    > for this user will submit client certificate with cn=user1 LB should accept this connection and reject all other connections.
  2. https://www.example.com/user2
    > for this user will submit client certificate with cn=user2 LB should accept this connection and reject all other connections.
Here’s one in its simplest form:
when CLIENTSSL_CLIENTCERT {
    set subject_dn 0
     Check if client provided a cert
    if { [SSL::cert count] > 0 } {
        set subject_dn [X509::subject [SSL::cert 0]]
    set user_in_path [string trim [HTTP::uri] "/"]
    if { ! ($subject_dn contains "cn=$user_in_path") } {
        reject
Would this one work for you:
when CLIENT_ACCEPTED {
    array set CNs {}
    for {set i 0} {$i < [SSL::cert count]} {incr i}{
        log local0. "[IP::client_addr]:[TCP::client_port]: cert $i; subject=[X509::subject [SSL::cert $i]];\
        [X509::issuer [SSL::cert $i]]; cert_serial=[X509::serial_number [SSL::cert $i]];"
        set CNs([X509::subject [SSL::cert $i]]) 1
    switch -glob [HTTP::uri] {
        "/abcdef" {
                     if { ! ([info exists CNs("cn=frontofficeuser")]) } {
                         log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] : rejected."
                         reject
        "/bcdefg" {
                     if { ! ([info exists CNs("cn=hruser")]) } {
                         reject
        "/cdefgh" {
                     if { ! ([info exists CNs("cn=facilitiesuser")]) } {
                         reject
        default {
                    reject
Only the leaf cert, [SSL::cert 0] is used for client SSL checking. This should also work;-
    set cn [class match -value [HTTP::path] starts_with dg_path_common_name_mapping]
    if {$cn ne ""} {
        Client certificate is required for this path
       if {![SSL::cert count]} {
          HTTP::respond 403 content "Client certificate required" noserver
          return
       } elseif {!([X509::subject [SSL::cert 0]] contains $cn)} {
           Client cert doesn't match required Common Name
          HTTP::respond 403 content "Client certificate does not match required name $cn" noserver
          return
you can use this irule:
when CLIENTSSL_HANDSHAKE {
  if {![info exists username]} {set username ""}
        set username [regsub -all ".*CN=(.\[^,\]*),.*$" [X509::subject [SSL::cert 0]] {\1}]
    if {[HTTP::uri] equals /} {
        HTTP::redirect "/$username"
    }elseif { !([HTTP::uri] starts_with "/$username") } {
        HTTP::respond 403 content {
            Not authorized
            You are not autorized to access this website
        } noserver
