irule for snat pool and data group and pool member
Hi Everyone,
Can anyone help me to create an irule:
Pool Name: Pool_Test Member: a. 10.10.10.2 port 0 (ALL) b. 20.20.20.2 port 0 (ALL)
Datagroup name: dg_test
Snatpool: a. snat1 - 10.10.10.1 b. snat2 - 20.20.20.2
what i want is if the client ip is a member of the datagroup dg_test, he will use pool_test but will use the pool member 10.10.10.2 port 0 (ALL) and will be snat to snat1. then everything else will fall to pool_test pool member 20.20.20.2 port 0 (ALL) and snat2
Please help me.
Give this a whirl.
when CLIENT_ACCEPTED {
    if { [class match [IP::client_addr] equals dg_test] }{
        pool pool_test member 10.10.10.2
        snat 10.10.10.1
    else {
        pool pool_test member 20.20.20.2
        snat 20.20.20.1
Give this a whirl.
        snat 10.10.10.1
    else {
        snat 20.20.20.1
is port not necessary on the configuration?
Only if you plan on changing the port. Since you have 0 configured for the VIP and your pools there’s no need for port in the pool command.
