According to the iApp wiki page Working with Tables it says that you can use the array set command with a lindexed value from a table variable -
array set columns [lindex $row 0]
So experimenting with this in tclsh I set a test variable -
% set test "{{
address 10.0.0.1
port 80
address 10.0.0.2
port 80
address 10.0.0.3
port 80
Now the result of [lindex $test 0] is this -
% lindex $test 0
address 10.0.0.1
port 80
Which is the desired result as the article explains.
However, when I try this on TCL you get an error -
% array set a1 [lindex $test 0]
list must have an even number of elements
In order to make it work I have to remove the curly brackets -
% array set a1 [string map {"{" "" "}" ""} [lindex $test 0]]
% parray a1
a1(address) = 10.0.0.1
a1(port) = 80
Am I doing something wrong or is the article wrong ?
The “Working with Tables” example shows a variable $row that contains 1 row of the table. In your example, the variable $test contains the entire table. If you want a single statement that operates on $test, it would be either
%array set a1 [lindex [lindex $test 0] 0]
or
%array set a1 [join [lindex $test 0]]
I see how they did it now. They are using a foreach loop which will remove the first set of curly brackets then the
lindex $row 0
removes the last set. When trying to use it in my iApps I am using a for loop which means I need to do the first lindex for the $test index then lindex 0 the result-
% for {set index 0} {$index < [llength $test]} {incr index} {
puts "----------------------------------"
array set a1 [lindex [lindex $test $index] 0]
parray a1
a1(port) = 80
a1(address) = 10.0.0.2
a1(port) = 80
a1(address) = 10.0.0.3
a1(port) = 80
