I rule
Can some give me an Irule to loadbalance multiple pools for the same VIP
pool x 443 would be default
Pool y 5222
pool z 5223
Try this,
when CLIENT_ACCEPTED { if { [TCP::server_port equals 5223}{ Pool pool-tcp-port-5223 } elseif {[TCP::server_port] equals 5222} {pool pool-tcp-port-5222} elseif{ [TCP::server_port equals 443}{ pool pool-tcp-port-443 } } Bye!!!
Giorgio
thanks romano will try and let you know
germano one more quick question Can i use a single SNAT for all these pools
i understand serverside connection is not available in CLIENT_ACCEPTED, so you may use TCP::local_port instead of TCP::server_port.
of course.
of course.
Thanks for the reply Nitass Can you explain me the difference between server_port and local_port
iRules Concepts: Considering Context part 1 by Colin Walker
TCP::local_port
TCP::server_port
TCP::local_port
TCP::server_port
thanks for sharing
thanks for sharing
Hi nitass, Soru but I don’t understand when you said: “i understand serverside connection is not available in CLIENT_ACCEPTED, so you may use TCP::local_port instead of TCP::server_port.” At this link (F5 Cloud Docs) the event CLIENT_ACCEPTED is a valid event! Where do I wrong? Thanx Giorgio
At this link (https://devcentral.f5.com/wiki/iRules.TCP__server_port.ashx) the event CLIENT_ACCEPTED is a valid event!
Where do I wrong?
i understand serverside connection is not established when CILENT_ACCPETED is triggered, so TCP::server_port won’t be available at that time.
e.g.
configuration
[root@ve11c:Active:Sync Failed] config  tmsh list ltm virtual bar
ltm virtual bar {
    destination 172.28.24.10:80
    ip-protocol tcp
    mask 255.255.255.255
    pool foo
    profiles {
        tcp { }
    rules {
        qux
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 7
[root@ve11c:Active:Sync Failed] config  tmsh list ltm rule qux
ltm rule qux {
  log local0. "[TCP::server_port]"
when SERVER_CONNECTED  {
  log local0. ""
 client
[root@centos1 ~] curl -I http://172.28.24.10
curl: (52) Empty reply from server
[root@centos1 ~]
 /var/log/ltm
[root@ve11c:Active:Sync Failed] config  tail -f /var/log/ltm
Mar  8 16:55:22 ve11c err tmm[15262]: 01220001:3: TCL error: /Common/qux  - no serverside connection established (line 1)     invoked from within "TCP::server_port"
Where do I wrong?
e.g.
configuration
ltm virtual bar {
    ip-protocol tcp
    pool foo
    profiles {
        tcp { }
    rules {
        qux
    source 0.0.0.0/0
        type automap
    vs-index 7
ltm rule qux {
  log local0. ""
 client
[root@centos1 ~]
 /var/log/ltm
Thanks you very much nitass! Giorgio
for 443 should i be doing SSL offloading on the cleint and server aswell or only client side offloading would work
