I need to create over 100 virtual servers
Creating over 100 Virtual servers and I was wondering if I can do it easily using TMSH. Unfortunately I don’t know tcl. Is there easy way to go about it?
You won’t need tcl but tmsh can help using a cmd like “tmsh create ltm virtual” and add the right syntax. You can add them individually or create a script, using bash for example, to do it en masse.
Check out the tmsh reference guide on askf5. Also, there may be scripted examples on Devcentral’s Codeshare too.
Hope this helps.
N
