HTTPS Redirect, with logging -
I feel sure that this has been asked before, but my search-fu seems weak today.
I have a number of ‘redirect’ iRules that I’m required to log when they fire - Simplest one being a http --> https redirect. Since upgrading to 14.1, my ‘standard’ iRule is failing -
Error is in /var.log/ltm:
Jun 20 09:45:14 f5vm011 err tmm7[27649]: 01220001:3: TCL error: /Common/Redirect_HTTPS <HTTP_REQUEST> - ERR_NOT_SUPPORTED (line 2)   invoked from within “HTTP::host”
The rule itself is:
HTTP::redirect “https://[HTTP::host][HTTP::uri]”
log local0. “HTTP Request for [HTTP::host][HTTP::uri] from client IP Addr [IP::client_addr] redirected to HTTPS”
I understand there is a new command to work with this…
HTTP::has_responded
However, I’m unable to get the syntax correct for it.
Note that when I comment out the ‘log local0’ stanza, the rule fires correctly, with no errors in /var/log/ltm
Any suggestions ?
Thanks !
Hello.
HTTP::has_responded syntax → F5 Cloud Docs
But take into account this → https://devcentral.f5.com/s/question/0D51T00006lU80eSAC/continuous-increase-of-tmm-memory-after-upgradation-to-v14103-and-a-fix-putting-if-httphasresponded-return-in-irule
Also, I recommend you to put the log line before the redirect.
KR,
Dario.
