I’m using BIG-IP VE 11.6.0HF4.
I cannot get HSL to work.
My syslog_server_pool is fine - I can see its UDP probes’
default send string
on remote SYSLOG server.
When I send traffic, /var/log/ltm shows:
Aug 10 17:25:49 BigIP-A info tmm[15093]: Rule /Common/hsl_SERVER_CONNECTED : Active members: 1, HSL handle is 'MDS:/Common/syslog_server_pool:UDP'; send result is '0'
Aug 10 17:25:49 BigIP-A info tmm[15093]: Rule /Common/hsl_SERVER_CONNECTED : 99.99.99.2:59012 -> 66.66.66.2:80 ::: 88.88.88.2:59012 -> 99.99.99.2:80
but no
Test
string is sent to the remote SYSLOG server (I confirmed this using tcpdump) and as you can see above, result
0
- why?
R’s, Alex
root@(BigIP-A)(cfg-sync Standalone)(Active)(/Common)(tmos.ltm.virtual) list v.Client1.http
ltm virtual v.Client1.http {
destination 66.66.66.2:http
ip-protocol tcp
mask 255.255.255.255
pool c.Client1.http
profiles {
http { }
tcp { }
rules {
source 0.0.0.0/0
source-address-translation { type automap }
vs-index 3
root@(BigIP-A)(cfg-sync Standalone)(Active)(/Common)(tmos.ltm.rule) list hsl_SERVER_CONNECTED
ltm rule hsl_SERVER_CONNECTED {
when SERVER_CONNECTED {
set pool syslog_server_pool
set hsl [HSL::open -proto UDP -pool $pool]
set res [HSL::send $hsl "Test\n"]
log local0. "Active members: [active_members $pool], HSL handle is '$hsl'; send result is '$res'"
log local0. "[IP::client_addr]:[TCP::client_port] -> [clientside {IP::local_addr}]:[clientside {TCP::local_port}] ::: [serverside {IP::local_addr}]:[serverside {TCP::local_port}] -> [IP::server_addr]:[serverside {TCP::remote_port}]"
root@(BigIP-A)(cfg-sync Standalone)(Active)(/Common)(tmos.ltm.pool) list syslog_server_pool
ltm pool syslog_server_pool {
members {
loghost1-net:514 {
address XX.XX.XX.XX
session monitor-enabled
state up
monitor udp
root@(BigIP-A)(cfg-sync Standalone)(Active)(/Common)(tmos.ltm.pool) show syslog_server_pool
Ltm::Pool: syslog_server_pool
Status
Availability : available
State : enabled
Reason : The pool is available
Monitor : udp
Minimum Active Members : 0
Current Active Members : 1
Total Requests : 0
Current Sessions : 0
Traffic ServerSide
Bits In 0
Bits Out 0
Packets In 0
Packets Out 0
Current Connections 0
Maximum Connections 0
Total Connections 0
Connection Queue Pool Pool and members
Number of connections queued now 0 0
Number of connections serviced 0 0
Queue head entry age (ms) 0 0
Maximum queue entry age ever (ms) 0 0
Maximum queue entry age recently (ms) 0 0
Average queue entry age (ms) 0 0
