Hello,
I have came across very strange behavior from f5. When default PoolA marked down by health monitor then VS is stays up because PoolB is up. Hence GTM will not mark node down for fail over. VS will only be marked down if PoolA and PoolB goes down. Is there anyway I configure if PoolA goes down mark VS down or mark PoolB down?
I have got following irule applied on VS.
Vishal
switch -glob [string tolower [HTTP::path]] {
"/test/*" {
pool poolB
default {
pool poolA
If I understand correctly, you’ve got a GTM Providing DNS for services to LTM VIP’s
To solve your problem, I would create a “Dummy” Virtual server on the LTM, with Pool A (or pool B, whichever is the non-default pool on the normal vip) and assign dependencies based on this availbility.
Therefore the GTM would only advertise/respond to requests via DNS if both pools are up.
Hope that makes sense.
do you have an actual default pool assigned? so not via the irule, but on the virtual server?
if you have one then that one determines the up / down state of the virtual server, so next to the irule you could do that.
also see: 404 Page not found | BIG-IP Documentation
