Yep. Either via iControl, or SNMP. From memory it’s in the systemStats. e.g.
my $System = SOAP::Lite
-> uri('urn:iControl:System/Statistics')
-> proxy("$sProtocol://$icUser:$icPass\@$icServer:$icPort/iControl/iControlPortal.cgi", cookie_jar => $cookieJar);
my($now) = time();
my $soapResponse = $System->get_global_statistics();
my ($status, $text)=&checkResponse($soapResponse);
$GlobalStatList = $soapResponse->result;
my $soapResponse = $System->get_http_statistics();
$HTTPStatList = $soapResponse->result;
my $soapResponse = $System->get_client_ssl_statistics();
$clSSLStatList = $soapResponse->result;
Which gives you 3 references $GlobalStatList $HTTPStatList $clSSLStatList which should give up al the stats you’d love to see. Including total connections.
