I’m new to iRules. And I’m trying to create what should be a simple iRule. I would like to redirect traffic from
http://www.domain1.com/products/new/\*
to
http://www.domain1.com/custom/new-items/\*
So far, here’s what I have
when HTTP_REQUEST { if {[string tolower [HTTP::uri]] starts_with “products/new/”} {HTTP::respond 301 Location “http://www.domain1.com/custom/new-items/\*”}
thanks for the help. I’m sure it’s just something simple that I’m missing.
HTTP::uri ALWAYS starts with / so your code should read:
if {[string tolower [HTTP::uri]] starts_with "/products/new/"
Also, if you just want to replicate whatever comes after new/ you are not going to get away with just doing a redirect. You’re going to have to capture everything after new/ to a variable to insert in the redirect.
Thank you for the feedback. Would you have any example on how to capture everything after new/. Sorry I’m really new to iRules.
I was afraid you’d ask. My TCL-fu sucks but this might be one way…
set firstUri [HTTP::uri]
set newUri [split $firstUri "/"]
foreach field $newUri {
lassign $newUri field1 field2 field3 fieldHOWEVERMANYFIELDSYOUHAVE
Then in the redirect instead of /* it would be /$field1/$field2 etc, etc.
Like I said, my TCL-fu stinks, but someone will probably provide a more efficient answer.
thank you. I’ll try playing around with that for awhile. Like you said maybe someone else already has a answer.
you an try this irule :
if {[string tolower [HTTP::uri]] starts_with "/products/new/"} {
set newuri [string map "/products/new/ /custom/new-items/" [HTTP::uri]]
HTTP::respond 301 Location "http://www.domain1.com$newuri"
