Having an issue with creating an iRule using HTTP::Path
Hello,
When I try creating an iRule I get the following error (I’m on v12.1.2):
error: [undefined procedure: HTTP::Path][HTTP::Path]
Here is the iRule (slight edit on URLs for security reasons):
    if { [class match [IP::client_addr] equals example_dg] } {
        switch -glob [string tolower [HTTP::Path]] {
            "/test/url/*" -
            "/test/this/url/*" {
                event disable
            default {
                reject
I do not see anything wrong with this rule in the syntax - but I’ve been staring at it for awhile and might have gone blind to what may be causing it.
Is anyone able to shed some light?
The right syntax is
HTTP::path
and not
HTTP::Path
The word path is lowercase
