GTM Statistics
I am working on the dashboard and trying to gonvert it for GTM. Is there a way to putt the Statistics list available for GTM related stats so I can choose which stats i want?
for instance STATISTIC_GTM_ACTIVE_CONNECTIONS
I just want to be able to pull the list of available stats.
Does this make sense?
Obviously I can’t type this morning.
I am working on the dashboard and trying to convert it for GTM. Is there a way to list the Statistics list available for GTM related stats so I can choose which stats i want?
No problem. The following methods return the respective list of statistics.
GlobalLB.DataCenter.get_statistics()
STATISTIC_GTM_METRICS_CPU_USAGE;
STATISTIC_GTM_METRICS_MEMORY_AVAILABLE;
STATISTIC_GTM_METRICS_BITS_PER_SECOND_IN;
STATISTIC_GTM_METRICS_BITS_PER_SECOND_OUT;
STATISTIC_GTM_METRICS_PACKETS_PER_SECOND_IN;
STATISTIC_GTM_METRICS_PACKETS_PER_SECOND_OUT;
STATISTIC_GTM_METRICS_TOTAL_CONNECTIONS;
GlobalLB.Link.get_statistics()
STATISTIC_GTM_LINK_TOTAL_BIT_RATE;
STATISTIC_GTM_LINK_TOTAL_GATEWAY_BIT_RATE;
STATISTIC_GTM_LINK_INBOUND_GATEWAY_BIT_RATE;
STATISTIC_GTM_LINK_OUTBOUND_GATEWAY_BIT_RATE;
STATISTIC_GTM_LINK_TOTAL_VS_BIT_RATE;
STATISTIC_GTM_LINK_INBOUND_VS_BIT_RATE;
STATISTIC_GTM_LINK_OUTBOUND_VS_BIT_RATE;
STATISTIC_GTM_LINK_TOTAL_INBOUND_BIT_RATE;
STATISTIC_GTM_LINK_TOTAL_OUTBOUND_BIT_RATE;
STATISTIC_GTM_LINK_LCS_OUT;
STATISTIC_GTM_LINK_LCS_IN;
STATISTIC_GTM_LINK_PATHS;
GlobalLB.Pool.get_statistics()
STATISTIC_GTM_POOL_PREFERRED_LB_METHODS;
STATISTIC_GTM_POOL_ALTERNATE_LB_METHODS;
STATISTIC_GTM_POOL_FALLBACK_LB_METHODS;
STATISTIC_GTM_POOL_DROPPED_CONNECTIONS;
STATISTIC_GTM_POOL_EXPLICIT_IP;
STATISTIC_GTM_POOL_RETURN_TO_DNS;
GlobalLB.PoolMember.get_statistics()
STATISTIC_GTM_POOL_MEMBER_PREFERRED_LB_METHODS;
STATISTIC_GTM_POOL_MEMBER_ALTERNATE_LB_METHODS;
STATISTIC_GTM_POOL_MEMBER_FALLBACK_LB_METHODS;
GlobalLB.Server.get_statistics()
STATISTIC_GTM_SERVER_VS_PICKS;
GlobalLB.VirtualServer.get_statistics()
STATISTIC_GTM_VIRTUAL_SERVER_PICKS;
GlobalLB.WideIP.get_statistics()
STATISTIC_GTM_WIDEIP_REQUESTS;
STATISTIC_GTM_WIDEIP_RESOLUTIONS;
STATISTIC_GTM_WIDEIP_PERSISTED;
STATISTIC_GTM_WIDEIP_PREFERRED_LB_METHODS;
STATISTIC_GTM_WIDEIP_ALTERNATE_LB_METHODS;
STATISTIC_GTM_WIDEIP_FALLBACK_LB_METHODS;
STATISTIC_GTM_WIDEIP_DROPPED_CONNECTIONS;
STATISTIC_GTM_WIDEIP_EXPLICIT_IP;
STATISTIC_GTM_WIDEIP_RETURN_TO_DNS;
System.Statistics.get_gtm_memory_usage_statistics()
STATISTIC_GTM_MEMORY_TOTAL_BYTES;
STATISTIC_GTM_MEMORY_USED_BYTES;
System.Statistics.get_gtm_global_statistics()
STATISTIC_GTM_IQUERY_RECONNECTS;
STATISTIC_GTM_IQUERY_RECEIVED_BYTES;
STATISTIC_GTM_IQUERY_SENT_BYTES;
STATISTIC_GTM_BACKLOGGED_SENDS;
STATISTIC_GTM_DROPPED_BYTES;
STATISTIC_GTM_TOTAL_LDNSES;
STATISTIC_GTM_TOTAL_PATHS;
System.Statistics.get_all_gtm_iquery_statistics()
System.Statistics.get_gtm_iquery_statistics()
System.Statistics.get_gtm_path_statistics()
Common::STATISTIC_GTM_PATH_CURRENT_RTT;
Common::STATISTIC_GTM_PATH_AVERAGE_RTT;
Common::STATISTIC_GTM_PATH_CURRENT_HOPS;
Common::STATISTIC_GTM_PATH_AVERAGE_HOPS;
Common::STATISTIC_GTM_PATH_CURRENT_COMPENSATION_RATE;
Common::STATISTIC_GTM_PATH_AVERAGE_COMPENSATION_RATE;
Common::STATISTIC_GTM_LDNS_REQUESTS;
Hope this helps…
This does. It actualy shows me that the stat isn’t there. Im thinking that I may have to look at the LB stats for them. I want to report on all the VS’s status as well as the number of active connections.
Since most that was under the Data Centers portion, I thought it might be a GTM specific stat but maybe not.
Where did you get that statistic anyway? The list of all statistics across all of the interfaces is in the Common.StatisticType API docs.
http://devcentral.f5.com/wiki/default.aspx/iControl/Common\_\_StatisticType.html
Click here
-Joe
Hahahaha. Kewl. I pulled it from the GTM Datacenter script.
